Is the SLM compatible with CDL3?
Discussion and support for MoTeC's Shift Light Module
Postby anthony_hk2001 on Sat Dec 31, 2011 2:23 pm
If I order the CDL3 track kit, can I upgrade the SLM-C to the SLM instead?
anthony_hk2001
Re: Is the SLM compatible with CDL3?
Postby chelspeed on Sun Jan 01, 2012 10:39 pm
If you want an answer before the end of the hols then why not download CDL3 dash manager and check if there is support for SLM? If you have an option for choosing colours then it must be able to run SLM if not then I guess it's SLM-C only.
chelspeed
Postby anthony_hk2001 on Mon Jan 02, 2012 9:30 am
I actually did that already but just want to make sure before I order the kit.
anthony_hk2001
Postby JamieA on Tue Jan 03, 2012 8:37 am
sorry for the delay in replying. Yep, the CDL3 will work with an SLM, or an SLM-C.
-Jamie
JamieA
Postby HKS_TRD on Tue Jan 31, 2012 7:06 pm
Whilst in the topic of SLM vs SLM-c is the SLM-C compatible with an M800 or ADL2? How exactly does the SLM-C differ from the regular SLM?
HKS_TRD
Postby JamieA on Wed Feb 01, 2012 11:23 am
slm and slm-c are basically the same except that the slm-c has a fixed colour layout.
regards,
Jamie
JamieA
Return to SLM
