EVO X MAP Questions
EVO X MAP Questions
Postby Aaron86 on Tue Jan 23, 2024 11:54 pm
Hi all!
This is the first time for me working on a Motec ECU, I have to tune a EVO X, I have some questions, does motec provide base maps? As the map I'am using is provided by another tuner and that should be fine for the car but I'd like to use base maps provided from motec if they are avaiable.
Anyway I got the engine started and working, I was able to tune the car so we could check everything was ok but fuel level gauge does not work, and I can't see lambda 1 from motec ecu manager (value stuck at 1,57)
I guess the lambda could be damaged as it is the oem one or misconfigured, but I can't really find a way to make the fuel level work. Can someone help me with this?
thanks
Aaron86
Re: EVO X MAP Questions
Postby Stephen Dean on Wed Jan 24, 2024 8:48 am
I have attached the installation notes for the EVO X M800 ECU, as well as the base files for the ECU.
13014A RS GSR MDC2 or std.zip
(17.91 KiB) Downloaded 1492 times
DVIN0015 Mitsubishi EVO X M800 Plug-In Installation.pdf
(581.48 KiB) Downloaded 1692 times
Postby Aaron86 on Wed Jan 24, 2024 7:26 pm
thanks a lot!
I didn't try the map yet, but I read the manual and didn't find nothing specific about fuel level, it just says that it shoud work cause these functions are preset, Will give it a try!
Aaron86
Postby Aaron86 on Thu Jan 25, 2024 7:40 am
Thanks! I tried to upload every map you attached but none of this made the fuel level work on the cluster. I tried reading the manual but can't find how to manage this... any ideas?
Aaron86
Postby Stephen Dean on Thu Jan 25, 2024 9:31 am
I'm not sure why the Fuel Level isn't working, the Fuel Level sensor feeds into the ETAS in the EVO X, not the M800, so it shouldn't have an affect on it's operation. If the OEM ECU is in place, does the Fuel Level work correctly?
Postby Aaron86 on Fri Jan 26, 2024 3:09 am
yes with oem ecu I have no problem, when I switch to Motec ecu fuel gauge isn't working, engine is working fine instead, anche I can't find a reason for this to happen
Aaron86
Postby Stephen Dean on Mon Jan 29, 2024 9:24 am
Do you have the CAN Messages setup as per the documentation.
Postby Aaron86 on Thu Feb 01, 2024 8:15 pm
yes, can setup address is like page 6 of the installation manual, it does not work. I tried all the base file you sent me, 2 of them puts fan always active (i didn't try to run the engine) the other base maps does not show fuel level at all, Everything else seems to work correctly, we did a base tune to test the new engine and we didn't find other problem till now
Aaron86
Return to M800 Plug-In ECUs
