Hi
had an issue this week with M130 GPA, June 2019 package, lastest tune updates.
Engine was nothing special, V8 multi tooth ref, single tooth sync, single CDi, ITB's
With the engine running when I tried to get a capture inputs trace I get a
'Failed capture' notification box, still had comms with ECU.
The power was cycled and a capture was available under cranking with
engine run switch off, tried again with the engine running and I got the same result
of 'Failed capture'
any ideas, thoughts
GWR Motorsport
