Motec M1 GTR Specific Channels
Discussion and support for Nissan R35 GT-R Plug-In ECU Kit
Postby fbikawi on Fri May 18, 2018 5:56 am
we are trying to setup a Motec C125 dash with a Motec M150 PNP.
the Motec C125 Dash Manager Channels List is showing a GTR specific channel list, but it is "Unassigned"?!
if we check the " Show Unassigned Channels" box, the channels will show and can be selected, but the channels will be not active on the dash screen; will always be Zero!
how can we use these channels on a C125.
it will be also very valuable if we want to use C1212 as a replacement of OEM Dash.
thanks
C125 GTR Channels Unassigned.JPG (183.69 KiB) Viewed 10553 times
fbikawi
Re: Motec M1 GTR Specific Channels
Postby adrian on Fri May 18, 2018 11:03 am
The channels are unassigned because you need to setup a CAN template to read the channels in. If you go to Connections>Communications and then add the GTR Template (see below) the channels in the template will be assigned and you can use them elsewhere in the config.
M1_GT-R_0x660_Version 1.CC7
(8.12 KiB) Downloaded 1081 times
Postby fbikawi on Sat May 19, 2018 8:02 pm
Dear Adrian,
thank you for the reply. GTR template was missing from my system file.
now all are working well :D
Great Support as usual.
fbikawi
Postby fbikawi on Mon Nov 12, 2018 11:51 pm
Hello Adrian,
i have noticed some dealer in the US now offering full replacement Motec Display to the OEM cluster.
i assume an Motec USA released an updated M1 GTR CAN template that include but not limited:
- Airbag Lamp Light
- Seat Belt Warn Driver
- Seat belt Warn Passenger
- Trip Distance.
- Trip A/B reset Switch
-Illumination Minus
-Illumination Plus
-Traction Light
-Tyre Pes FR
-Tyre Pes FL
-Tyre Pes RR
-Tyre Pes RL
- TPMS Fault
- Door Right Status
- Door Left Status
can we have a copy of the updated GTR M1 template please.
thank for your usual support :)
fbikawi
Postby adrian on Tue Nov 13, 2018 9:12 am
Can you please send me an email, support@motec.com.au, requesting the templates.
Adrian
Return to Nissan R35 GT-R Plug-In ECU Kit
