m1 tune trigger question
PostPosted: Sun Aug 17, 2025 3:25 am
by Clean RC
Hello..
Please forgive me for asking.. I am playing around in the GPR package for my M150, setting up i/o's for my project. I noticed that for GM LS engines there is the LS1 trigger that is 24x, and a LS7 that should be 58x but when I select the LS7 trigger it shows 25 on the tooth count. AM I doing something incorrect, or do I need to manually change the trigger settings. Thank You for helping a somewhat newby..
Re: m1 tune trigger question
PostPosted: Mon Aug 18, 2025 10:12 am
by z0mgchris
Pretty certain that if you have set the trigger in the drop down menu that it generally ignores that setting.
In the F1 help for tooth count it shows this -
Engine Speed Reference Tooth Count
The number of evenly spaced teeth in the Reference pattern. Forexample:
•Missing tooth modes such as "60-2" would have 60 evenlyspaced teeth
•The number of physical teeth for multi-tooth modes
NOTE: Only used when Mode help specifically mentions this setting, eg "Multi-Tooth", "One Missing" and "Two Missing"modes.
PostPosted: Mon Aug 18, 2025 11:28 am
Selecting the Reference Mode does not change the Reference Tooth Count parameter. Set it to the correct number of teeth (including the missing teeth), especially if you want to do an Input Capture, as this tooth count is used to calculate the generated angles between edges.
PostPosted: Sun Mar 15, 2026 9:14 am
by Sylvain_L
Stephen Dean wrote: Set it to the correct number of teeth (including the missing teeth)
I found the number of teeth, but I did not find where to define missing teeth.
PostPosted: Mon Mar 16, 2026 3:31 pm
The number of missing teeth is set by the selection of the Reference Mode, so if you have a 36-1 trigger wheel, you would select Crankshaft One Missing Four Stroke and and set the Reference Teeth to 36. The ECU will then look for the 36-1 pattern.
