Hello all,
I am circling back to this thread after doing some more research into the idle control system in M1 Tune and trying to get a better understanding of how all of the parameters work together to control and maintain target idle aim.
One parameter that I've discovered which I haven't heard anything about in previous webinars, forum posts, etc. is the Engine Crank Fuel Volume Compensation.
I understand that this value is meant to correct for the additional fuel required due to poor air/fuel mixing at low air speed during cranking. I'm wondering if the current values in my package are drastically off and contributing to the hard-start issues we're having while trying to tune this Yamaha R6 engine. Is there a method to calculate good starting point values for this table when starting a new engine tune from scratch?
Here are the current values left over from a previous engine using a variation of my current package:
- Engine Crank Fuel Volume Compensation.JPG (83.73 KiB) Viewed 7972 times
Do these seem reasonable? I am essentially at square one in tuning this engine (recently fixed an air leak in the intake system, so going back through to start re-tuning the efficiency map with this leak fixed).
As always, any help is greatly appreciated.
Thanks,
Benjamin
